Problem viewing mailbox accounts configuration on Portal
Anyone else seeing a problem with managing their mailbox accounts through the portal? We are unable to either reverse the order of the list (A-Z, Z-A), or see anything except from the first page (1-10). Using the dropdowns to select anything else isn't working.
Tried on IE7 and IE6, on two different accounts.
1 REPLY
Plusnet Leader
Plusnet Leader
I've just had a look at this and have logged into the member centre as yourself and had no problems with the mailboxes.
I selected from the different drop down options and hit 'GO'. This brought up the resultant list of mailboxes.
Are you still having problems?Huh
