Problem activating ADSL Line
tcs2000
I used to be connnecting to Plusnet running off the phone extension.(Been fine for a year)
Extension in lounge.Master socket in bedroom.
Until a couple of weeeks ago everything had been fine.
Then I couldn't get an ADSL line.
Advised previously to connect straight to master socket when there was a problem.I did this and all ok.
Decided to buy 20m cable so I could connect straight to master socket.
Ok until a couple of days ago.
Now...when I shut down and go to use PC in morning...switch on PC and no ADSL line straightaway.
I disconnect from wall....cable from modem (which is internal PCI ) etc to try and get it to work.
Yesterday nearly 2 hours before I got one.Today 30 mins.
Once I get ADSL all is ok and I can get it for 10 hours+...no problem
Is there a problem at Plusnet end?
Are you doing tests on the line?
I know I'm coming up for the 8mb upgrade soon.
