Premier
Premier
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 2500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 3072 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1007 kbps
So am I being throttled now on Premier?
Test 8.20 am
Premier
IP profile 2500, PN Profile 2500
Speed Net Under 1Mb, Namasco Under 1mb
Premier
I am also getting really slow speeds on premier. I have raised a ticket, which has come back inconclusive. My speeds are below 500k on all speed test I have tried including bt speed test. What is going on? I am on a fixed 2 meg connection.
Date Speed Achieved (kbps)
15-02-2007 08:52:01 657.8
15-02-2007 08:50:04 594.6
14-02-2007 23:18:16 244.1
My last 3 test from plus net speed test.
Peter
Liam
Premier
That is not the kind of service I would expect to receive from Premier (and shouldn't be the case).
Have you rebooted your modem or router to see if this resolves the problem? Do you have an intermittent connection? Does it get worse at peak times?
Unless you've hit the management levels then you should be able to get upto line speed on a speed test, especially in the morning.
Premier
I am no where near my management levels, the speed was worse last night I was only getting 244 then. I have rebooted all my equipment, router and PC. I do not have an intermittent connection, just really slow speeds. I raised a ticket last night this is the number 21327974
Peter
sam
Premier
Hi peepsw,
I have flagged your ticket with one of our faults team.
There should be an update on your ticket within the next 30 minutes or so.
Premier
I also seam to be throttled at present;
Down stream sync 4256 kbps
PlusNet MSR profile 4000 Kbps
Service received 3000 kbps max
Since Friday last week I have not exceeded 3000 kbps, on what should be a 4M connection.
Account type; Premier option 1
Chilly
Liam
Premier
Chilly,
Have you run the performance tester to see what your BT IP Profile is?
Are you on Tiscali? Could just be that your exchange is busier? Premier customers should be getting a better experience now than they were a month ago - as far as our own network is concerned.
Premier
Thank you for that I have just done a speed test at speedtest.net here are the results.
URL=http://www.speedtest.net][/URL]
Premier
This is the first time I have experienced less than maximum profile speed - therefore the above does not apply. Not only that it is in OFF PEAK!
Ordinarily my only speed drops after a synch blip. This is not the case. IP profile and PN Profile 2500. Could be a concern given the way capacity seems to becoming more of an issue. Will keep an eye on this and come back if it persists
Also just into second day of Billing Month - and less than 100Mb usage
Wld appreciate some PN suggestions as to what is happening?
Premier
Any Thoughts?
Results: Thornton Code: MYTHT
County: West Yorkshire
Enabled: 19 Nov 2003
VP capacity at this exchange is currently showing as Green.
Click here for further details
Premier
Slightly OT, but what do you use to compile these stats?
Premier
@liam
My connection is BT Wholesale
I have not yet checked my profile BT IP, but I will give that a try.
I would guess its not exchange/PlusNet contention, as I would show higher speeds over night.
It needs some invertergation, but I have been up to my neck in vmware and rdesktop.
@rnetworks
There is a description in the following thread;
http://portal.plus.net/central/forums/viewtopic.php?t=38277
Chilly
Plusnet Staff
Plusnet Staff
Premier
A sync rate of 4256kbps would indicate a throughput rate of 3500kbps, from:
http://www.plus.net/support/broadband/network/dslmax_guide.shtml
Be interested to see if the BT IP Profile agrees.
Plusnet Staff
Plusnet Staff
Premier
Any Thoughts?
Everything looks fine our side and no MSOs showing for your exchange. Could be a number of different things, I'd suggest rebooting your PC and router/modem and see if that makes any difference.
