Premier vs PAYG
mapletree
Premier vs PAYG
I am thinking about upgrading from 'Home Surf' to Premier or PAYG. However I can't figure why there is such a price differential between these two products. I have studied the specs and they seem virtually identical. If so, why would anyone choose the Premier account or am I missing something?
TIA, M
Premier vs PAYG
The two accounts are the same as far as functionality are concerned but how data is paid for is where it differs. With PAYG you pay for each GB of data above the 1GB inclusive. With premier you have no limits to the amount you can download.
The PAYG account also does not have traffic shaping applied and is considered a 'clean' connection, whereas the premier account does have traffic shaping and SUP allowances and P2P/Usenet/FTP allowances which can affect your speeds to varying degrees.
If you intend to use more than 5GB of data a month then premier will work out chaeaper, if less then PAYG is what you want.
Premier vs PAYG
I'm afraid there are limits on how much you download!!!!!!!!!!!!!!!! even with unlimited premier
Premier vs PAYG
I think Peter meant there is no limit as to how much you can down load on the PAYG package.
Premier vs PAYG
No, I meant PlusNet don't have a cap on premier (or any product for that matter) so while your connection may slow down the more you download, you don't reach a limit after which you can't download anymore.
All products are still subject so contention.
Premier vs PAYG
so slowing down your connection to dial up speeds is not a capHuh?
Whatever
mapletree
Premier vs PAYG
I get it Cheesy
I'm not sure I understand the traffic shaping. Can you explain more about this?
Premier vs PAYG
Where have you been for the past 4 months Wink
Please see the vision statement in the announcements forum and the Sustainable Usage Policy. There is also some useful info on the PUG website here.
Traffic shaping involved prioritising certain types of traffic so things like HTTP (web) and email always have priority. Below that comes P2P/FTP/Usenet who's speeds are reduced to allow enough bandwidth for the higher priority traffic.
Basically there are allowances for total usage and P2P/Usenet/FTP. If you exceed those allowances, various things can happen, primarily your speed is reduced (traffic shaped) for certain types of data in stages between the various peak periods. It then all gets reset at your next billing date (ish).
Premier vs PAYG
Oh, sorry. Smiley
