Possible webmail improvement
I just noticed that the webmail facility on the Plusnet portal doesn't seem to include a "reply to all" function. Any chance of this being added at some point in the future? I don't use the webmail that often but I use reply to all quite frequently within Outlook and I'm sure others would find it a welcome addition to the portal.
Cheers
Jon
1 REPLY
RE: Possible webmail improvement
Hi Jon,
The simple answer to this is Yes, I have seen a prototype of our new webmail solution which has this functionality. This is still in the development stage so it is likely to be a few months away, but I can assure you that it will be worth the wait!
Cheers,
Ian Wild
PlusNet Customer Support
