Ports
Julie
Ports
Hi
Sorry to post this, I am sure I have missed this somewhere, but ...can someone please point me to the latest information regarding the ports that plusnet are blocking by deafult...many thanks Smiley
Ports
Me too. PlusNet decided to start blocking ports without telling me.
Ports
I seen it on the Usertools but for the Life of me I cannot find it.
Ports
The two postings in question are
THIS explaining what is being blocked and what was already blocked
THIS showing they are (and now have) been removed from premier
There was a problem where some customers experianced some of the blocks continueing, which I also believe will be corrected by now.
Julie
Ports
Hi Philip
Many thanks for your reply, so do we have an updated list anywhere of the ports they are blocking now please?Huh
Ben_Brown
Ports
On Premier accounts we only block the following:
135
445
1434
On other accounts these ports are also blocked:
137 (TCP/UDP)
139 (TCP/UDP)
12345 (TCP)
1026 - 1029 (UDP)
1023 - 1028 (TCP)
Julie
Ports
Thanks Ben for your reply,
Then can you please explain why my firewall is blocking attacks on these ports you have listed.
I am just curious...good job its a good firewall Wink
I am a premier customer.
Ports
Do you mean the first 3 ports listed?
This is casued by the inability to block connections between customers connected to the same Juniper gateway.
Customers on different gateways or external internet connections are blocked.
IE: 2 customers on PTN-AG1 can connect, but 1 on PTN-AG1 & 1 on PTN-AG2 will fail.
Julie
Ports
Yes Phillip I meant the first three ports, and thanks for the information, much appreciated Smiley
