Portal problems?
LiamM
Portal problems?
Getting a lot of this...
We were unable to complete your requested action. This may be the result of a temporary fault.
Please try again in a few minutes.
Should you require further assistance, please contact our support team on 0845 1400200
Something up?
LiamM
Portal problems?
That took about 30 attempts to post. This probably will too.
Portal problems?
no prob here
Portal problems?
yep - getting it too....
Portal problems?
Liam, I have been unable to log in fro 20 mins.
just got in now. This is the same issue which occurred yesterday at about the same time, only today its worse.
Portal problems?
I'm seeing the same error. Only 1 in 10 or so attempts to load a page actually works.
Julie
Portal problems?
It has taken me over 30 attempts to try and post the exact same message Liam Sad
Portal problems?
Same problem with me also. No such problem on PlusNetters though.
Wink
Portal problems?
Seems to be getting better now....
Portal problems?
I was going to post this on Chris' thread until Liam locked it so I'll post it here instead :twisted:
A few of us are, I've only had it a couple of times so far, but others are getting it much worse...
Portal problems?
Do you get refferals from PlusNetters? Smiley
Portal problems?
Spoke too soon.....
Mind you, there have been about 20 or so posts in the last six minutes....
Is this forum contention kicking in? :lol:
Portal problems?
This has been raised as a problem and will be fixed as soon as the issue is identified, it seems to be only a few of the portal servers which is why it is intermittent.
Portal problems?
Not yet, an Idea for the portal though :razz:
Julie
Portal problems?
Thanks Stewart,
It is becoming quite unusable for me I cannot even browse the forum now.
1 in 10 clicks bring up the error. Sad
