Portal page viewing problems with IE7
mitchell20
Been using a beta version IE7 with WinXP for some time now but yesterday I installed the latest build (5335) and now I can no longer view any account details, connection deatils or service status pages. The text down the left hand side of the screen does load but nothing else.
I'm also using a beta version of Windows VISTA with IE7 on a different HD (not sure of that build) and that works OK. BTW VISTA is fantastic!!!!
Yes I'm aware that IE7 is still in beta phase but just seeing if anyone else has the same problems.
1 REPLY
Hi!
Yes this has been discussed before. It depends which Beta2 version you have. The 5335 doesn't work with the account pages but the earlier version does.
Have a look at this thread
Cheers,
Lee
