Portal login
MikeLerwill
Portal login
I am having trouble logging in to the portal today and yesterday.
This only occurs from the login section on the main page. It always tells me something was wrong but when I then re-enter the same information again I can login in without a problem.
If from the main page I select login from the very top menu and enter my details here it always works correctly. I know this was a problem in the past and had been mentioned in the forums previously but had been fixed.
Is anyone else seeing this or is it just me?
Portal login
It happened to me earlier today, but I put it down to the fact that I was switching between user accounts at the time.
I closed IE and upon re-launch it worked first time.
Portal login
Humm, strange, I have had exactly the same problem as this every time I try to login. No I just dont bother using the homepage to login!
