Portal Issues
Portal Issues
Anyone else, noticing that the F9 Portal is slower than usual tonight
browsing other sites is fine, just seems to be the portal
regards
Mike
1 REPLY
Portal Issues
i think i've sorted it
just updated my dsl-g604t with the new firmware for august, and most of the configuration is different, and it had reset the mtu and added a new mru section as well.
think its still buggy as now can't set idle timeout to above 5minutes, which is a bit pointless really.
regards
mike
