Portal Guide - Don't miss out on any features
I tried using the portal guide to find out where your line speed test (whatever it's called) is lurking but it doesn't seem to be mentioned there.
Please could you tell me where I find it and then make sure it also appears in the portal guide?
I also should like to know how to:
> You can use the search facility to find posts that you have made or posts containing specific words etc.
It's probably very obvious but the only search stuff I can see is at the top of the page for Yahoo, Google etc.
Tim
RE: Portal Guide - Don't miss out on any features
The +net speed test is at:
http://monitor.plus.net/
As for the search i think what you are looking for it is at the top of the forum IE. enter the adsl forum and it is right at the top of the page.
Jim
> Hi,
> Thanks
> Tim
The plusnet speed test is at
and the search link you are looking for is right next to the "post new topic" link
espresso_mick
Use the above link to go to the page where you can test your speed. I dont know if it is mentioned anywhere in the portal guide. You could just keep is as a 'favourite' in your browser for easy access.
When you enter one of the forums, there is a search tool link in purple above where it says 'Topic Starter'.
Mick
Tim,
The speed test is available from:
http://speed-test.plus.net.uk/
Best Regards,
Dave.
| David Watson. Unmetered & ADSL solutions
| Technical Support. for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
Thank you very much everyone.
Each time I looked for the search I was already following a threaded discussion - well that's my excuse! :deadhead:
Tim
Hi Tim,
Let us know if we can help you any further.
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
