Portal Banners...
craigbrass
Portal Banners...
Hello,
As has been said by another PlusNet user on these forums, it is a bit rediculous offering people who have Broadband Premier a Broadband Plus package which is a lower package than they already have.
In my opinion, banners should check to see which package you are on and then offer you better packages (as in more expencive) on the same band (residential or business) you are on aswell as other services in the same band you are on (like plustalk for instance assuming the user does not already have it).
Best Regards,
Craig Brass
Portal Banners...
As the banners are part of the header, which applies to all pages on the PN website, I think it would be a lot of work to change it, and make it more intelligent.
Could be easier to have an option to collapse the header bar alltogether?
craigbrass
Portal Banners...
Well actually, I would like to see banners advertising services that are new and stuff so don't want it collapsed altogether.
Fixes: 5
Portal Banners...
Peoples usages changes at times. It could be an advantage to see or be reminded of some of the lower packages that might save them money or be more suitable to their needs at a certain time.
Phil
