Portal Access
Portal Access
I wanted to test my speed and check a few stats on my account, but am unable to access the required areas of the portal. If I click on "connection settings" in the left hand column, I get the page minus any icons or links....just the header "connection settings".
I guess this could be a browser issue, so deleted all temporary files etc but to no avail. Is it down, or is there a more obvious reason (usually the case!) for my inability to access the relevent areas of this site?
Thanks in advance.
JonathanW
Portal Access
You don't happen to be using the IE7 beta, do you? As I've seen other reports of this browser causing issues with certain sections of the portal. We're looking at what we can do for when the final version is released, but for the time being the only other advice would be to use a different browser to access any sections of the portal that you're having problems with.
Portal Access
I do indeed use the IE7 beta. Enough said, IE6 here I come. Thanks!
