Port 8443 problems
Delmonte
Port 8443 problems
Hi
Can anyone check if they can access this login page https://cp.mygisol.com:8443
I have tried everything to access it including changing a router , turning off firewalls, clearing cache etc etc. but I just get page cannot be displayed. I have asked F9 if they block this port but they say they do not.
If someone else can access it then I'll know for definate it is not F9.
Derrick Smiley
francoise-hardy
Port 8443 problems
Well, I just accessed it ok straight away. GISOL Control panel page.
Hope this is of use.
robinh
Delmonte
Port 8443
Great Thanks it eliminates F9 from the problem
Rgds
Derrick
Port 8443 problems
yes, i can access it a well, but i'm not coming through f9's portal
just so you know it works coming through from another isp
regards
mike
