Poor connections
stathe
Poor connections
Similar story this morning with only the modem connected , problems connecting with plusnet even when both lights are on,whoops gone again, have to open DSL status and click connect , Seems sometimes to be not connected despite set to stay on
Have you tried
a firmware upgrade, i assume your using a router?
Poor connections
Hi stathe,
Sorry to hear your problems are continuing.
For future info, it is better appending to your original thread as opposed to opening a new one.
It means that we can keep track of what has happened and been suggested before without having to jump between threads.
Hope you understand.
Maybe add any further posts to the original and let this one die.
