Plusnet speed tester.
jagger
Just had a go at this and found that it doesn't work in Firefox but does in Internet Explorer 7.
Firefox
IE7
Fixes: 70
Hmmm, seems to be working fine for me in Firefox. In fact when I've used it in the past it's been with Firefox too.
Does clearing your cache help?
Rgds,
Plusnet Products Team
holdtight
Working just fine here using firefox and same as Bob never had a problem with it
jagger
Nope.
Cleared cache and disabled all add-ons.
Version 2.0.0.5 all fully updated.
IE7=
holdtight
Is it just using mybroadbandspeed it does this ?
Have you tried any other speed tests to see if the problem can be replicated elsewhere
Plusnet Staff
Plusnet Staff
Fixes: 159
Does this speedtest work for you in Firefox? I ask because it's by Ookla, the same as the PlusNet speedtester.
 Chris Parr
 Plusnet Staff
p_w_d_stone
I originally had problems because of our use of NoScript, but PlusNet kindly fixed it Javascript wasn't required for the test to run.
I have been using mybroadbandspeed.co.uk on Firefox since launch without any problems.
jagger
Exactly the same.
A few others.
http://resources.zdnet.co.uk/speedtest/ 1780 kbps
http://www.bandwidthplace.com/speedtest/results.php 1.4 megabits per second
http://www.thinkbroadband.com/speedtest.html 1885.80 Kbps ( 1.8 Mbps )
http://www.speakeasy.net/speedtest/ Download Speed: 0 kbps (0 KB/sec transfer rate)
Upload Speed: 133 kbps (16.6 KB/sec transfer rate)
http://www.my-speedtest.com/ Your bandwidth speed is * : 1.74 Mbps
p_w_d_stone
Strangeness- are you running a rules based software firewall at all?
jagger
Weird,
On speedtest.net it doesn't show any result unless I compare it.Then I get
Liam
Very strange.
The BBMAX checker is also using the same software as ours.
Seems to work in both IE and Firefox for me without a problem. I wonder if there is a Firefox extension which might help pinpoint the problem... Hmmm..
jagger
Liam,
That result from speedtest.net is from December apparently so it did work once upon a time but not any more in Firefox.
12/16/2006 4:22 PM GMT 1917 kb/s 245 kb/s 67 ms Maidenhead ~ 150 mi
Same result on BBMAX.No download speed around 150 upload.It's rubbish because I'm getting around 1900 on a lot of other tests and regularly download around the 240Kbps mark so I'm not worried about speed particularly.My real problem is packet loss but I'm puzzled by this.
James
Jagger,
Could you possibly let us know which Firefox extensions / plugins you are using?
jagger
@ peterstones,
Running ZoneAlarm pro for several years without problems.Now got a router online but nothing firewalled in there as far as I know.If it was one of them then surely IE7 wouldn't work either? (he guessed)
jagger
yup,hang on.
Adblock 0.5.3.043
Adblock filterset.G updater 0.3.1.0
British English Dictionary 1.19
Fasterfox 2.0.0
Fire ftp 0.97
NoScript 1.1.6.06
United States Dictionary2.0.0.6
Password hasher 1.0.4
Forecastfox 0.9.5.2 (disabled)
Just tried the test with all add-ons disabled and got the same result. :shock:
