Plusnet portal login
mapletree
I wish the plusnet portal had the option to always login via the secure version (https). It is a risk to have your password transmitted in plain text, especially if you are away from home.
I know the secure version exists because you can edit the address bar but the portal keeps taking you back to the unsecure version (e.g. for entering your webmail usernames/passwords).
csogilvie
IIRC, the fact the initial page is HTTP doesn't matter - it's the TARGET of the information that matters, which for the Webmail page is https:// and is the same for the portal login.
Yep, the portal & webmail logins are secure even if the page with form on isn't - just had a look with Ethereal to make sure Wink
So this is already happening.
What we need is secure passwords which is another topic altogether.
Add your support here: http://portal.plus.net/central/forums/viewtopic.php?t=33226 ;-)
Which reminds me; my sigs about due a revamp...
mapletree
How can I check this from Firefox?
TIA.
Right click -> view source and look at the form's action tag...
Or alternatively do what I did and use Ethereal to sniff the packets leaving your PC - you'll notice that the portal page itself comes via http but the login exchange is done using https.
csogilvie
Right Click, View Page Info, Forms tab.
mapletree
