Plusnet Webcams
Moggy
Plusnet Webcams
No big deal but how do you view Plusnet Webcams? All I get is:-
Axis ActiveX Camera Control
The AXIS ActiveX Camera Control, which enables you to view live image streams in Microsoft Internet Explorer, could not be registered on your computer.
I'm using Vista if that helps!! I just wanted to make sure everyone is working Cheesy
Plusnet Webcams
I had this on my Vista laptop when using IE7. Using Firefox, they can be viewed.
Moggy
Plusnet Webcams
Thanks Cairns,
normal stuff then, new software new problems...
jmd
Plusnet Webcams
I get the same message and I use Windows XP with IE7 - so don't believe they can be actually viewed..............
Plusnet Staff
Plusnet Staff
Plusnet Webcams
There should be ActiveX control that downloads with the cams. If not try this:
http://www.axis.com/techsup/cam_servers/dev/activex.htm
Moggy
Plusnet Webcams
Nope that didn't work. Reading the write up it says it supports XP Pro and 2000 SP4, so don't think it's gonna work with Vista.
