Plusnet/Force9 IP range in blacklist?
oliverb
When checking my IP against openrbl.org I note that someone called bliab.com appears to have a block against 212.159.121.*
This appears to stem from three customers in this block with current "open relay" blacklistings.
@SPAM/spamsource: 212.159.121/24: 553 PROXY 212.159.121.12,51,77 force9.co.uk plus.com BSWN OSW SN 2003-05
lhorwath
Are you actually getting problems because of this? Do you know where these are blocked? I have passed this information onto the Network team but they generally only investigate claims from the affected IP user. I imagine if it is because of an open relay, we will have already notified them to this vulnerability.
kind regards
Luke
oliverb
I don't believe it's an immediate problem.
I've seen no evidence that this "bliab.com" list is actually in use anywhere, and I would be unlikely to use a list that blacked a whole IP range on the basis of three suspected relays within it.
