PlusNet whats gone wrong
with the new VMBU it's not updating usage I'm showing zero for today and last night which I know is wrong
How can I keep a check on my usage when the VMBU is borkedHuh
Good question.
You shouldn't have to pay for extra GB's if you can't tell where you're near to using them.
vic_newey
I think your usage is going on mine as I think its suddenly registering more than I am using Evil
Suddenly it's caught up a little showing off peak usage for today ............
Plusnet Staff
Plusnet Staff
The data is currently being collected once every 4 hours for Plus and Premier accounts, it takes a while to process so it will be a little behind at the moment. The collation interval is going to be changed to 2 hours shortly.
Data for PAYG accounts should be up to data as that is processed seperately so should be at most 2 hours behind.
Mine shows far more than I have used including gaming and p2p which I never ever use. I have raised a ticket but no response as yet.
I think mine is updating every 4 days -
@ chrisofcov
:lol: Hahaha.
