PlusNet Premier
PlusNet Premier
I am currently on plusnet broadband plus. I am using around 4 -5 gb per month. I do like going on xbox live which accounts for a lot of my bandwith. However, according to the website I am unable to get 2mb speed due to the length of my line.
Please could someone advise me if would be beneficial to me to get the premier service with its contention benefits?
Cheers.
PlusNet Premier
Based on your description fo your usage, I can't say if it would be advisable or not.
Do you see any problems with your current service?
What benefits do you want to see?
Are you worried about chages in your usage may not be totaly possible?
If so, what changes?
PlusNet Premier
I just want to get the fastest and most efficient speed and service for my money within the limitations. Wink
Cheers.
Plusnet Staff
Plusnet Staff
PlusNet Premier
The choice of Broadband Plus or Premier is really going to depend on what your usage is going to be and whether the value added features of Premier would be of use to you.
If your main use is Xbox live then you probably wouldn't notice much difference on Premier. If you use P2P or Usenet then you would.
