Please Help Speed gone from 4740 to 87.6 kbps
petsyb
My peak usage this month is 392.15MB however it feels like i'm being slowed down max speed download for the last few days has been around 20k a second
PLEASE HELP !
Plusnet speed test has me at 87.60kbps
23-12-2006 06:29:49 87.6 kbps
22-12-2006 08:09:04 269.1 kbps
24-10-2006 13:57:05 1728.4 kbps
28-07-2006 18:10:55 4740.4 kbps
infact i can upload 4x faster than i can download !
petsyb
Acroding to http://www.speedtest.net/
108 kbps down
373 kbps UP
Anyone else want to post their results!
2109 kbps down
375 kbps up
Hi
No Probs here
On a Red exchange btw Sad
Whats your MSR set to on the plusnet site.
Try the BT speedtest, to see what your IP profile is set to. Also have you have any losses of sync lately or problems with your phone line. These can all cause your Max Stable rate to plummet, with associated drops in speeds. Whats speeds have you had previously before this happened?
petsyb
Plusnet has my speed set at 5mb
i'm connecting at 5.5mb
no losses of syn
though having lots of problems with pages not coming up as are some otheres as i see !
past speed was fine could pull files down at around 500k a second , now i'm lucky to get 20k Sad
James
PLEASE HELP !
Have you read the sticky at the top of this forum?
Have you run a BT Speedtest?
petsyb
BT Test Results - What do these mean ! note this test was ran at aprox 6.30am today (sunday)
__________________________________________________
http://speedtester.bt.com/
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 250 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5792 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 143 kbps
http://portal.plus.net/my.html?action=stable_rate
Your High-speed Broadband Service
Your current broadband speed is 5000 Kbps
My service was fine up to a few days ago ! i have neither installed any other software, chenged any settings or hardware etc , just gone on a go slow ! Sad
petsyb
Tec support replied to my querry Questions | ID: 20952906
Why do tec support always blame my exchange it's been on red for yages and my speed has never been a problem,
reduced speed at peak times try 24/7 at 0.5mb or slower on what untill last wednesday was around 5mb Evil
_______________________________________________________
Answer to my question to tec support
I note that your exchange capacity is at 'red' as seen on our usertools site here:
http://usertools.plus.net/exchanges/?exchange=Ripley&exact=832&plugin=vp
So you can expect to see reduced throughput, particularly at peak times.
James Please comment !
Fixes: 8
That reply is carp! Exchange contention has nothing to do with getting an IP profile of 250 kbps which is the reason for your slow speeds. BT will have set it down to a low figure because there have been problems getting a consistent connection at higher speeds, probably with frequent drop outs. If you line stays connected at the higher speed with no disconnections for three days that speed should rise.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
petsyb
But i have been on 8mb connection for months and have always had a connection of over 5mb and my excnage has always been red !
and
I have had no dropouts since the first few couple of weeks i went to 8mb
so is the 'IP profile for your line is - 250' slowing me down and if so has this been set by BT ? :?
Anyone !
petsyb
So is it that my bras profile has been set very low if so can plusnet reset it or will i have to wait 3 to 4 days ? , my modem is and has always synced above 5mb
sinewave
There is something very wrong going on.
If you are syncing at 5Mb+ and your ip profile is 250kb/s then something is very very wrong.
This could be caused by an intermittent line fault. If you can, check your router logs to see if you are getting disconnected at all - it can happen without you noticing. Also listen carefully to the phone line. listen for hiss and crackles.
If "something" is causing your router to disconnect/reconnect this will make the BT gear think your speed needs to be reduced. If you can find out what is causing the disconnections you're half way to a fix.
Whatever, there ~is~ something wrong and just being fobbed off by PN blaming the exchange being on red is ridiculous.
petsyb
I think I may have found the cause, Tuesday just gone (19th dec) I tried a friends filter for no more than 30 seconds , it seemed to work ok but I'm guessing now it may have synced badly.
could a one of bad connection almost a week ago have caused my BRAS profile to be set so low, surley it would have gone back up by now if so ?
this as far as I can tell is the only time my connection has been interrupted, line sounds clear and is still syncing at above 5mb whenever i connect
petsyb
if so Can someone at plusnet reset it ?
does anyone know the best way to manually restore it ?
can someone from the Comms Team please tell me what i should Do !
