Pings and Frozen pages
Sorry about all the info here,
Just wondering if anyone had any comments on the data? Seems that things are getting slower and slower.... just not techie enough to know where to go from here.
Will raise a ticket but any thoughts appriciated Smiley major prob if doing work online then loosing it when connection drops and now i can't play nay games online as the pings are in the high hundreds- thousands.
Operation Data Upstream Downstream
Noise Margin 29 dB 11.5 dB
Output Power 12 dBm 19 dBm
Attenuation 31 dB 44 dB
Ok how about these? though they seem to be wildly variable.
I know i have to raise a ticket but am wondering if anyone has a clue as to why my connection keeps dropping? no loss of sync acocrding to my router and wireless signal is strong. Speed tests are spotty thoghseems BT is ok and other speed testers say im very slow.
BT speed tests.
1699 kilo bits per second (Kbps), 12/10/05 21:30
1854 kilo bits per second (Kbps), 13/10/05 21:44
1384 kilo bits per second (Kbps), 13/10/05 22:27
Not able to connect to internet (all green lights) 13/10/05 22:29
6 disconnects from games total gave up, 23:00
BT speed tests
1212 kilo bits per second (Kbps), 15/10/05 11:24
1929 kilo bits per second (Kbps), 15/10/05 22:51
Adsl guide speed test
Downstream 615 Kbps (76.9 KB/sec) 664 Kbps (inc. overheads)
Upstream 236Kbps (29.5 KB/sec) 254 Kbps (inc. overheads
BT speed test
1588 kilo bits per second (Kbps), 16/10/05 22:07
1850 kilo bits per second (Kbps), 16/10/05 01:47
ADSL guide
Direction Actual Speed True Speed (estimated)
Downstream 814 Kbps (101.8 KB/sec) 879 Kbps (inc. overheads)
Upstream 240 Kbps (30.0 KB/sec) 259 Kbps (inc. overheads)
BT speed tests
1108 kilo bits per second (Kbps), 17/10/05 17:11
1128 kilo bits per second (Kbps), 23/10/05 17:52
580 kilo bits per second (Kbps), 23/10/05 20:18
677 kilo bits per second (Kbps), 23/10/05 21:18
Zen net
Download size: 200 KB
Download time: 3.328 seconds
Download speed: 481 Kbps (kilobits per second)
Client IP Address: 84.92.186.173
Downstream 452 Kbps (56.5 KB/sec) 488 Kbps (inc. overheads)
Upstream 243 Kbps (30.4 KB/sec) 262 Kbps (inc. overheads)
BT speed test
272 kilo bits per second (Kbps), 24/10/05 17:19
Damian
