Ping problems
Ping problems
I play Day of Defeat & Red Orchestra and since yesterday my pings on server's I usually play on are over 500ms, usually my ping is <40ms Are there routing problems ?
Ping problems
Can you post a traceroute to the affected servers please.
Ping problems
The pings are back to normal now. Anything changed?
Midville
Ping problems
Maybe a bit of bad weather.......
Ping problems
... or indigestion. Wink
3Mb FTTC
Ping problems
Things seem to have almost settled down now Cheesy
Ping problems
It's gone again! just tracerouting...
Tracing route to 195.242.236.247 over a maximum of 6 hops
1 <1 ms <1 ms <1 ms 192.168.0.1
2 107 ms 110 ms 97 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 32 ms 25 ms 29 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 36 ms 56 ms 34 ms vl23.thn-gw1.plus.net [212.159.4.19]
5 31 ms 28 ms 29 ms ge0-1.lonap.lon.rapidswitch.com [193.203.5.86]
6 30 ms 28 ms 27 ms ge-1-24.pup.mer.lon.rapidswitch [87.117.214.2]
Trace complete.
And
Tracing route to 212.187.208.143 over a maximum of 6 hops
2 274 ms 345 ms 216 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 32 ms 25 ms 26 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 27 ms 27 ms 29 ms 195.50.117.169
5 34 ms 28 ms 26 ms 212.187.208.143
Trace complete.
This is my mate :
Tracing route to 212.187.208.143 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 10.10.2.2
2 51 ms 36 ms 33 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 14 ms 16 ms 16 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 15 ms 14 ms 16 ms 195.50.117.169
5 15 ms 18 ms 19 ms 212.187.208.143
Something needs fixing!
Laugh
Ping problems
Don't know whether this is applicable, but I did a speed test last night at about 9pm (ish) and I was suffering with 66% packet loss. It sorted itself out after about 5 mins, but things did look a bit dodgy for a while.
Ping problems
I had the same problem in Day of Defeat Source just now, ping is usually 30-40, but it shot up to 500. I reboot my router and the problem was then fixed.
Ping problems
I'll try that now. What's your gaming name?
Moderators note by John (johnessex) full quote of preceding post removed as per the Link:rules
Ping problems
Heh its like this for me. I try to talk over vent but my pings are messed up. But ingame they are fine. This is annoying aswell. It takes about 15 seconds to connect to a vent server. Normally it takes less then a sec. This is on and off. Plus net will you please fix this.
Ping problems
I've recently moved to PlusNet from BT and I used to have a Ventrilo ping of around 20 but now it can get to 5000+
My connection is fine apart from that. Is anyone else having this problem?
P.S. If anyone from PlusNet is reading this I've tried to raise a ticket under 'Connection Problems' - maybe you should have a simple link on the site to allow people to raise tickets?
Ping problems
Is anyone actually doing something about the problem or do i have to raise a ticket, I've just tried it again it's gone again. TBH i'm getting pissed off with the shit service that plus net are providing, infact I wouldn't even call it a service. I'm still waiting for the update and all they can put is the message that always put
We acknowledge your request to be regraded to DSLMax as a priority and will endeavour to submit your order ASAP.
Regards
Customer Support
[Moderator's note by Mark (pcsni):Swear filter avoidance removed]
Ping problems
Stanlee, could you tell me how to raise a ticket? I can't find any simple link anywhere and I've just had to leave our COD2 server because of frequent disconnects. My ventrilo ping was back up again after I thought it was fixed Sad
Ping problems
I Have a similar problem with Ventrilo and was told by PN that it was due to the fact that my Vent provider is using a port (4092) that the PN Elecoya (Line Shaping) kit does not recognise as a Vent port. I cant get the provider to change the port and PN wont add it, so I'm stuck.
