Ping problems?
willhome
Ping problems?
ok all of a sudden my online gaming ping has gone from 20-40 to 100 ping on uk servers. It never been like this before and wasnt like this couple hours ago before i went how.
Any reason it could have done thisHuh?
willhome
Ping problems?
Tracing route to 83.142.49.18 over a maximum of 30 hops
1 3 ms <1 ms <1 ms 192.168.8.1
2 125 ms 126 ms 128 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
3 135 ms 134 ms 140 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 132 ms 133 ms 136 ms gi5-0-22.pth-gw2.plus.net [212.159.4.5]
5 135 ms 134 ms 138 ms peer2.ge7-8.gsr12012.lon.tsnglobal.net [195.47.2
43.183]
6 133 ms 141 ms 131 ms core3.fe0-0.zebra2.8.lon.tsnglobal.net [83.142.5
1.14]
7 130 ms 131 ms 132 ms 83.142.49.18
Trace complete.
here is a route to it
Ping problems?
Try rebooting your modem/router to get on another gateway than ag3 and see if the ping improves.
willhome
Ping problems?
i did this shortly after after realising i was on that gateway and knowning about its problems but thanks
Ping problems?
@willhome
would be a good idea to check your pings etc at different times through the day and then at peak times which i belive on plusnet is 16:00 to 00.00 and compare them, i myself find that through the day my pings are fine but at peak time they can go right up,
Aslo my d/l through the day are fine but peak times they slow down to 25k- 50k when otherewise i can d/l at 230+kb,
If you find that in the day your pings are fine ,but at peak times they are high then its probarley down to contention and plusnets traffic shaping,
