Phone/Modem interference
OK I'm having a slight problem & have run out of ideas on how to fix it.
I recently got a new phone & have found that when my modem is connected there is terrible static when i try to use the phone, also when ever i pick up or hang up the phone it cuts off my modem.
At first i thought it may be a problem with the filter so I've tried 3 different ones but to no avail.
Any suggestions would be a great help.
1 REPLY
Problem solved.
Was indeed a filter problem.
Thanks Anyway.
