Peak Time Problems?
Peak Time Problems?
Plusnet your current service is shocking. I haven't had a decent speed at 'peak-time' this week, yet after this time my top speed comes back...
09-09-2006 10:14:47 1946.5
09-09-2006 10:14:29 1969.1
09-09-2006 10:14:12 1960.7
09-09-2006 00:16:14 1688.6
09-09-2006 00:15:57 1952.5
09-09-2006 00:15:47 1887.1
08-09-2006 21:17:41 708.3
08-09-2006 21:17:26 759.7
08-09-2006 21:17:09 1232
08-09-2006 08:03:21 1820.8
08-09-2006 08:03:03 1914.5
08-09-2006 08:02:47 1960.9
07-09-2006 22:27:38 1858.6
07-09-2006 22:27:22 1961
07-09-2006 22:27:11 1876.1
07-09-2006 19:21:53 653.3
07-09-2006 19:21:38 329.8
07-09-2006 19:21:14 342.7
07-09-2006 08:17:36 739.5
07-09-2006 08:17:21 868
07-09-2006 08:17:02 1035.4
06-09-2006 23:01:54 1898.5
06-09-2006 23:01:38 1782
06-09-2006 23:01:16 1834.7
06-09-2006 19:46:44 545.2
06-09-2006 19:46:27 756.4
06-09-2006 19:46:10 1200.8
Coiincidence? I don't think so. Others have been reporting bad gaming pings and speeds suring this time so it must be a network issue or, in my case as I have been LLU'd, an issue with Tiscali's management.
A month ago I created a ticket reporting unstable speeds and gaming pings and PN changed the profiling on my line. Due to this I went down to a 2mbps top speed but the stability was better and so for a while I was happy again. But now I'm getting the above results at peak-times and gaming is impossible once more (and something I use 70% of my connection for!).
If your or Tiscali's network cannot handle the amount of users at 'peak-time' then you should be doing soemthing about it now! I will not be putting up with thsi sub-stanard service much longer, I was ready to leave before you made the change to my line but stuck around because you
seemed to fix this issue...
Ticket 19990696 if anyone cares... :x
Peak Time Problems?
Plusnet CSC please can you respond to ticket 19990696. It has been 4 days since I left my last response.
The latest change you/Tiscali made to my line on 11/09/06 has made things more unstable than ever. I have a higher target speed again but am still receiving less than 1mb speeds at most times and pings are so high and variable it is impossible to play games online.
I am now requesting that I be transferred back to the BT IPstream connection I had before (to be done at your cost). I am tired of the problems I am having with the LLU service you changed me to and am not waiting any longer for things to be sorted out. It seems it is too unstable for my line or Tiscali have over-subscribed the service in my area which is why the problems mainly happen at peak-times (when everyone is probably using their connection).
I also qualify for transfer back to BT Wholesale as I received my LLU notification on the 5th May - before the opt-out was added to the LLU FAQ and I never received a second notification with opt-out option.
Please address this issue today. Thank you.
Mand
Peak Time Problems?
I've added a response to your ticket for you and passed this back to our faults team for further escalation.
Peak Time Problems?
Thank you Mand. Smiley
However, I can't find the option I need to request a move back to IPstream in the Help & Support pages. an anyone help me find the path? :?
Peak Time Problems?
AFAIK, There is no specific section within the "Help & Support" section that covers the request to move back to IPStream. Just add the request to your current ticket. That's what I did.
Peak Time Problems?
I would do but in her last reponse Mand said it was better to raise a specific ticket for this :roll:
Peak Time Problems?
In that case, choose any section in "Help & Support" and follow it to the end of its path, when the "Help Assistant" popup window is displayed, close it. In the window underneath will/should be an option to "Ask a Question".
Mand
Peak Time Problems?
Just raise any ticket, and in the 'your comments' bit advise which transfer option you prefer, you can cross reference to the other open ticket if you wish as it may save some time and ticket tennis. Smiley
Peak Time Problems?
Thank you again Mand.
Ticket 20318951 has now been raised requesting internal migration back to Ipstream.
As this process takes a month please can someone from PN CSC action this immediately. Thanks.
Liam
Peak Time Problems?
I have added a response to your ticket and assigned it to the correct department for you.
Peak Time Problems?
Still awaiting my notice that PN have received a MAC key to transfer me back to IPstream. This was requested by PN on 20/09/06.
After another weekend of bad connectivity and speeds I want off this LLU hell... now!
Please can someone from PN CSC chase this issue today - ticket 20318951.
Thank you.
