Pathetic!
Pathetic!
so i do a speed test 5 mins ago and i get 254kbps download speed...
and how is this broadband?!
i thought the problems were supposed to be fixed?!!
Pathetic!
Hi Ansell,
Whilst I appreciate your frustrations, your post doesn't seem to bear any resemblance in asking for help from anyone, it just seems to be a "rant" which isn't useful in these parts Cry
Why don't we start again from the beginning and see if we can help you out old chap Wink
Try posting some stats from your router with the results from a couple of speedtests, be they from BT or BBmax
I would be inclined to check to see if your exchange is suffering from VP (Virtual Path) Capacity Issues, all the usual stuff, I'm not trying to teach you to suck eggs as you've been around a while now - the more info you put into your post, the more people can help you!
Are you on Broadband Plus by any chance? - If you are, I would recommend PAYG, I'm a convert now Wink
Kind regards,
Roger.
Pathetic!
hi, yes im on broadband plus but dont really want to change due to the price differance.
here is a test
something is definately wrong! my upload is better than download!
router stats:
ADSL Speed (DS/US) 6176/448 Kbps
Noise Margin 6.1 dB 20.0 dB
Line Attenuation 36.0 dB 20.0 dB
hope you can help me fix this Smiley
Pathetic!
I'm on premier opt 1, and have been waiting over two weeks for PN to get my speed sorted. I am getting vey disgruntled as the problem has been ongoing for the last couple of months.
router stats:-
Actual Data Rate
Up Stream 448 (Kbps.)
Down Stream 6784 (Kbps.)
Operation Data Upstream Downstream
Noise Margin 20 dB 4 dB
Attenuation 40 dB 31 dB
I am paying £21.49 for this... :roll: ...
Theresa.
James
Pathetic!
Guys.
BT Speedtest is your friend (some of the time).
Isitme
Pathetic!
I am paying £21.49 for this... Rolling Eyes ...
Theresa.
Guys.
:roll:
James
Pathetic!
Quoting http://dictionary.com
"Guys"
2. Usually, guys. Informal. persons of either sex; people: Could one of you guys help me with this?
Ner.
Isitme
Pathetic!
Ah, office/wine bar slang.Smiley
Don't think much of this definition
3.Chiefly British Slang. a grotesquely dressed person
Always thought guy(s) was American, eg. Guys and Dolls Shocked
What is Ner? (I trust you did not miss a d off the end Wink )
James
Pathetic!
A facetious sound generally used to imply "told you so" Smiley
Isitme
Pathetic!
Then it should have a small n and more r's :lol:
Pathetic!
how is this helping me with my origional question?!!
i have posted my stats and a speed test can someone at plusnet look at this please and tell me what is going on?!!
James
Pathetic!
Hi Ansell,
Unless I'm mistaken, I cannot see any reference to a BT Speedtest anywhere?
Beetroot_Bertie
Pathetic!
Guys.
Indeed. It seems to be the lying/cheating type of friend I don't need at the mo:
17:38 336 down/257 up
http://www.speedtest.bbmax.co.uk/results.php?t=1172943561&v=835880
17:45 656 down/349 up
http://www.speedtest.bbmax.co.uk/results.php?t=1172943940&v=835921
17:51 BT Speedtester
IP profile for your line is - 2000 kbps
DSL connection rate: 448 kbps(UP-STREAM)
3648 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1439 kbps
17:54 730 down/198 up
http://www.speedtest.net/result/94078711.png
18:06 346.60/369.08
http://www.thinkbroadband.com/speedtest/results/id/117294513535154624236.html
It seems the BT test is telling some porky pies to me. Just when I though the BB+ speed issue was resolved.
Hmmmmph.(The sound of another exasperated customer)
James
Pathetic!
My personal opinion would be that you are suffering from exchange contention, rather that network management issues at our end.
Re: Pathetic!
the fastest way to get away from this problem is basically change ur isp. Thats what I'm going to do once my contract finishes.
