Pages slow to load
AndyR
Pages slow to load
Recently I have changed to uTorrent and used scheduler to not download between 1600 and 2400.
When I try to download during these times I cannot get any speed and the http is abysmal, cutting out with no pages loading.
Turning uTorrent off and surfing causes no problems between 1600 and 2400, pages load OK.
Edit - forgot to say surf and download OK outside the hours quoted. end edit
Doing some speed tests wireless and ethernet gives some remarkable results:
Wireless
Ethernet
Wireless
Ethernet - impressive
Whilst downloading P2P packets, HTTP fails
I have learnt another lesson - never too old to learn
regards
Andrew
Lost Series 3 is out on Thurdays...
Fixes: 8
Pages slow to load
Looking at those wireless results I suggest you make sure that the MTU on the router is equal or larger than the MTU on the wireless PC.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
AndyR
Pages slow to load
Elvin
The MTU on the router [192.168.1.1] was on auto, I have changed this to manual and set it at 1500. Is what you mean to check?
regards
Andrew
Fixes: 8
Pages slow to load
You obviously have a different router, but that sounds right. Has it made any difference? (fingers crossed for you)
Uncle_Meat
Pages slow to load
Just a quick thought on top of that good MTU advice.
Your wireless connection, is it 802.11b or 11g?
Also, what kind of signal quality do you get?
I ask as 11b, which is nominally supposed to be 11Mbps (signalling speed) at best, gives an actual thoughtput (download speed) of around 6Mb or thereabouts. If you have an iffy signal with 11b, this could drop signalling to say 5.5Mb for example, with an associated drop in throughput. And so on. 11b can drop to 2Mbps or even 1Mbps signalling, which will be quite a bit slower than your line can support by the looks of it!
HTH?
Pages slow to load
I'd also be interested to hear what wireless hardware you are using to connect.
Centrino Wireless Chips, for example, are reasonably well known to apply their own silly power saving rules, resulting in lousy throughput, even when the link status tells you its connected at a far higher rate than your ADSL is capable of (54Mbps)
Fortuitously the settings can be changed to force it to work sensibly.
I've found that the Netgear and Belkin USB WiFi Dongles perform at a similar rate to an ethernet cable (when talking about ADSL Download speeds - obviously currently you can only get around half the throughput on WiFi ATM Wink )
Pages slow to load
Erm, yup - you fell for the sales jargon didn't you!
The marketing peeps decided to pull a fast one when talking about wireless speeds. 11Mbps WiFi is 5 each direction, lousy when compared to 100Mbps wired connections, which will give you 100Mbps both ways.
The fact that wireless is only half-duplex also means that content inevitably ends up being buffered, which can confuse things even more, and make performance look even worse.
Please excuse the age of the quote (04) but its an old problem! - When it refers to 'Standard WiFi' it means the standard then, 802.11b (Advertised as - 11Mbps)
Anybody who describes ordinary Wi-Fi as carrying 11 megabits per second is, technically, correct. But the payload on 802.11b is half that; 5 megabits - and that's shared amongst all users. Also, the rate drops as you move away from the access point; 802.11b drops back to one megabit when the signal gets weak.
As a rule of thumb, if you take the Wi-Fi standard bitrate, you can work out the payload easily enough by dividing by two. Rarely, it will be faster; usually, a lot less. Put two access points on the same channel in the same area, and it can be so much less you may even wonder if you're connected.
source...
AndyR
Pages slow to load
Latest test done on Dusseldorf - better readings considering the time of day - net is always busier in the evening.
As for b or g setting it is 802.11g signal strength excellent, speed 54Mbps. Wireless security managed by McAfee Wireless Security
Linksys wireless router WAG54GS, firmware 1.0.08 and Hello Tosh gotta Toshiba laptop
regards
Andrew
Pages slow to load
What about the wireless on the Laptop?
Is it Centrino, or something else?
AndyR
Pages slow to load
Hiya
Wireless on Toshiba is INTEL PRO/Wireless 3945 ABG
Ethernet is Realtek RTL8139/810x
regards
Andrew
Uncle_Meat
Pages slow to load
source...
Heh. Well, that was my point. Smiley
Wireless=Smoke and mirrors to confuddle Joe Public.
Looking at the OP's wireless speedtest results, they could easily have been 11b running for all it's worth at 5.5Mbps signalling.
