PLEASE PLEASE HELP ME! im loseing conection aprox every 1 hr
hi people
please if you have any ideas ...please say :?
i jioned plus net about 6 months ago...i pay 14.99 pm for the service
for the 1st 3 months everything seemed to work fine---for the last 3 months i have had a lot of disconections
and all i have to do is is reboot my router and im back on line again (although any downloads are lost etc)
AT 1ST IT ONLY SEEMED TO HAPPEN WHEN IT WAS RAINING HEAVY OUTSIDE might be coinsidance but unlikely
i have been through the check list on plus net help- for loss of conection...and i have replaced my telephone and router and adsl adaptors...
i dont think the plus net auto disconect feature would see my line as not in use because im normally web browsing and msn etc when im cut off
i have had BT here to check the line a few times ...but they are reluctant to admit anything is wrong with the line and will not help anymore ...they tell me i must contact my ISP before they will take any action at the ISP request
this is my 2nd router and the problem still persists
:shock:
to give you an idea what the hard ware is saying:
for the last hour i have monitord the router log...and i got cut of once in that time (the web pages just slowed up and ground to a hault)
router conection status says this even when lost conection occurs:
Connection Status on router
On Netgear ADSL ROUTER GD834GT
Connection Time 01:57:43 Connecting to Server Connected Negotiation Success Authentication Success
Getting IP Addresses 87.114.8.149 Getting Network Mask 255.255.255.255
the router log says this even when conection is lost :
Sat, 2000-01-01 00:00:07 - Administrator login successful - IP:192.168.0.2
Sat, 2000-01-01 00:00:21 - Initialize LCP.
Sat, 2000-01-01 00:00:21 - LCP is allowed to come up.
Sat, 2000-01-01 00:01:21 - Initialize LCP.
Sat, 2000-01-01 00:01:21 - LCP is allowed to come up.
Sat, 2000-01-01 00:01:29 - CHAP authentication success
Sat, 2000-01-01 00:01:34 - Send out NTP request to time-g.netgear.com
Tue, 2006-12-05 19:17:49 - Receive NTP Reply from time-g.netgear.com
Tue, 2006-12-05 19:37:49 - Administrator login successful - IP:192.168.0.2
if i ping my dns server when the web pages is starting to slow down and finally conection is lost...this is what it says:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
Reply from 212.159.6.9: bytes=32 time=41ms TTL=60
Ping statistics for 212.159.6.9:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 40ms, Maximum = 43ms, Average = 41ms
C:\Documents and Settings\jon7>ping 212.159.6.9
Pinging 212.159.6.9 with 32 bytes of data:
Reply from 212.159.6.9: bytes=32 time=43ms TTL=60
Request timed out.
Reply from 212.159.6.9: bytes=32 time=42ms TTL=60
Request timed out.
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Minimum = 42ms, Maximum = 43ms, Average = 42ms
Reply from 212.159.6.9: bytes=32 time=39ms TTL=60
Reply from 212.159.6.9: bytes=32 time=45ms TTL=60
Reply from 212.159.6.9: bytes=32 time=48ms TTL=60
Request timed out.
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 41ms, Maximum = 41ms, Average = 41ms
Reply from 212.159.6.9: bytes=32 time=40ms TTL=60
Request timed out.
Request timed out.
Minimum = 40ms, Maximum = 42ms, Average = 41ms
Request timed out.
Reply from 212.159.6.9: bytes=32 time=44ms TTL=60
Minimum = 43ms, Maximum = 48ms, Average = 45ms
Request timed out.
Reply from 212.159.6.9: bytes=32 time=46ms TTL=60
Request timed out.
Minimum = 41ms, Maximum = 46ms, Average = 43ms
as you can see it looks like a lot of packets get lost
this is looking like its way over my head....so i hope some of you tech peeps can help?
nothing has changed in system and no new parts etc--- my cat5 connected pc...or in my wireless conected laptop...both lose conection at same time , so its not a pc or wireless problem i think
i have upgraded the router firmware to latest spec last week...still no differant
thanks for stayin with me if you made it this far
best wishes for now
john
this is when i am conected:
tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.228.155]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 43 ms 48 ms 48 ms lo0-plusnet.thn-ag1.plus.net [195.166.128.80]
3 43 ms 45 ms 41 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 45 ms 44 ms 42 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 42 ms 42 ms 41 ms gi1-1-22.ptn-gw5.plus.net [212.159.4.6]
6 44 ms 40 ms 42 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 53 ms 41 ms 50 ms 212.58.238.133
8 41 ms 41 ms 49 ms 212.58.238.33
9 44 ms 44 ms 43 ms pos6-0.rt0.mh.bbc.co.uk [212.58.239.30]
10 44 ms 50 ms 48 ms virtual0.mh.bbc.co.uk [212.58.228.155]
Trace complete.
i tryed to do the BT SPEED TEST over the last 20 mins
all it says is :
The system is currently busy. Please try again shortly, however if this problem persists, raise the issue with your service provider.
and 30mins later it says:
Unexpected result received when querying the network to find your services connection details. Please try again shortly, but if this problem persists raise the issue with your service provider.
is this normall for the BT speed test page ?? Evil
john
adsl Modem quotes this conection rate when im conected (has ben 1h 20 mins so far yipppeee)
will try again when disconected:
ADSL Firmware Version A2pB018e.d16f
Modem Status Connected
DownStream Connection Speed 3734 kbps
UpStream Connection Speed 619 kbps
VPI 0
VCI 38
System Up Time 01:21
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 40683 58181 0 1401 8710 01:20:00
LAN 10M/100M 16927 15252 0 2822 803 01:21:27
WLAN 11M/54M 44075 28308 0 6218 732 01:21:25
ADSL Link Downstream Upstream
Connection Speed 3734 kbps 619 kbps
Line Attenuation 45.0 db 21.8 db
Noise Margin 10.1 db 12.5 db
and a few mins later:
Noise Margin 8.7 db 13.0 db
update
noise margin fallin
System Up Time 02:16:26
Noise Margin 7.9 db 13.0 db
come to think on it ...when the problem started a few months ago ....that may have been the time plus net upgraded my line to faster speed
could this be the problemHuh
thanks
john
just got cut here is what modem reports before reboot
modem reports:
Noise Margin 5.4 db 13.0 db <<------
is this my problem??
and would a slower conection help?
from your line stats I'm guessing that you are on an LLU circuit, don't think the BT speed tester will work for you :?
This is likely to be the cause of your problem: Netgear ADSL ROUTER GD834GT
I have exactly the same problem and so do many others. Its down to the router. There are some other posts about Netgear routers doing the same thing.
James
Yup, I've come across some problematic DG834GT's in my time too. If you can borrow a friends modem or router to see if this helps, it will at least let us diagnose the problem further.
Otherwise, change your filters and ensure that you are wired directly into the test socket behind the master faceplate.
hi guys thanks for the input
i have tryed a other netgear router a more basic model without the wireless addon
the other router did seem to last a little longer with out drop outs----but again when it rains hard outside this is when i get cut more often
is it possible that since my line was upgraded a few months agao that its made the sync more important with the router?
and can my conection speed be turned down to work better with the netgear?
can any1 advise on a router that would work better?
thanks a lot guys
best wishes
j7
Fixes: 8
When it rains heavily, can you hear any reduction in the quality of your ordinary telephone?
(Try the quiet line test: 17070 option 2)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
hi
no the line test is very quiet and no crackle etc
the BT engineer has ran his scope on the line from the house and cant see any problems (although he only comes when it is mostly dry)
all the conections to my box have been opened and clean by BT...the only other possiblity is the wire from the exchange is getting water in
its raining heavey here atm this is the router stats atm
Connection Speed 2393 kbps 591 kbps
Noise Margin 7.8 db 13.0 db
best wishes for now Cry
Plusnet Staff
Plusnet Staff
The number of problems I've seen because of the weather must run into the hundreds, if not thousands, especially with Max.
The way Max works is that it operates on the limits of ADSL technology and therefore the limits of your phone line. With the old fixed rate (512, 1Mbps and 2Mbps) speeds you would likely have had plenty of SNR to spare, so when it rained the SNR would drop, but not enough to cause a problem or disconnect the connection.
With Max though it probably only needs a few dB drop to cause a drop. What to do? Chances are as you say, some part of your line is getting water logged, to fix it there's really two options, increase the target SNR (and thus lower the speed) so that there's plenty of margin for when it rains and the SNR drops or try and find where the water logging is happening.
Unless it's something obvious on your property find the water logging may not be easy, but we can raise a fault to get it looked into. If you go to
http://faults.plus.net
complete all the details and provide us as much information as you can and we can get it looked into. Lowering the speed may be easier and quicker to do, but I'd suggest having it looked into to see if there's anything else that we can do.
hi dave
many thanks for that
i will follow your instructions and filll in the form
but if the worst happens and they cant fix it ...im happy to get my speed lowerd or change settings on my router to slow things down....and give me more stable conection
many thanks for now
john
