PAYG
PAYG
with all the restrictions on Plus & Premier I have advised one of my friends who is on Plusnet to move on to PAYG because they use between 7 & 10GB a month and the 19.99 option includes 10GB.
Can any PAYG user confirm that the plan is not restricted on P2P? If it is then there will be no point in her taking my advice.
1 REPLY
Fixes: 57
PAYG
There is no P2P limit within the 10GB (you can down the whole allowance as Linux Distros - isn't that the oficial reason for using P2P) however it will still be subject to prioritization in the Ellacoyas.
What this means is that you are unlikely to get full speeds at peak periods. However using the new Azereus encryption might get round even that slow down. :
