PAYG
PAYG
I know you get a 1GB and you have to pay for every gig over that you use but will it only go up to 21.99 the same price as unlimted or could you be charged more then 21.99
Alecto
PAYG
Hi
No, you'll be charged for what you use, so if you're going to use a lot, then switch to Premier.
There is, I believe, a limit to the charge, but I've seen various views on what this limit is, and it's definitely higher than £21.99.
PAYG
I am also unsure of the upper limit, but it is indeed above £21.99
You can however set your own limit, so that you are not charged over X amount.
