PAYG Exceeded Allowance
I have Data Transfer Watch set-up on my account for £16.49 so that I know how much my internet will cost each month. Today is the last day of my billing period and I have checked my usage and it has JUST added another 2gb to my account taking me over the limit I set. How is this possible? Can I have this reversed some how? I don't want the extra 2gb as there is no change of using it before it is reset at midnight.
Plusnet Staff
Plusnet Staff
Fixes: 159
I'll arrange for the extra usage block to be removed from your account and ensure you don't get charged extra than your data transfer watch this month.
 Chris Parr
 Plusnet Staff
Thanks for that. Is my assumption on how it should work correct? i.e. once I hit my limit I should only be able to access the one page to add more bandwidth if I choose, and the rest of the net is disabled? If that is correct any idea why it didn't happen this time? Thanks again.
Plusnet Staff
Plusnet Staff
Fixes: 159
That is correct, once you reach the data transfer cap you should be restricted to the page so you can only add more before browsing.
I'm not sure why it didn't happen this time, I'll get someone to look at it.
 Chris Parr
 Plusnet Staff
Thanks again for the quick reply, the service level on this forum is amazing! Can't imagine any other ISP has response times like that. Every query I have raised on here has had a response in minutes. KUTGW Cheesy
Plusnet Staff
Plusnet Staff
Fixes: 159
:mrgreen: Thanks, the level of service is something we want to keep getting higher.
 Chris Parr
 Plusnet Staff
dannykos
i think there's something funny going on with some of the PAYG accounts on changeover of billing month - as thats more than a couple of threads now with either limits not being adhered to - or new month data profiles not being implemented properly.
Nick_Russell
I had a similar problem. Last month I went over my 2GB limit in month and had 2GB added - all OK. Then towards the end on the month I approached 4GB and I had an email saying I had exceed my limit and another 2GB would be added - again all OK (bit of a pain with a day to go but that's another story!).
However when I checked my usage it said my limit was now 8GB ie 4 GB had been added. I raised a ticket and I just got an explanation how the system works (not too helpful) but the next day the invoice was raised and it was for the correct amount ie 6GB. So the problem with me was just the usage reporting and not billing.
My usage page now shows 4.3gb free usage and 0 paid for usage but my usage limit shows 6gb? I am in to my new billing period now how come I still has a usage limit of 6gb and the message about going over my limit? Is this all part of the same problem that will be resolved before any extra money it taken? Thanks in advance.
I could be wrong, but this looks like you are on the first day of the new account period, and things are still sorting themselves out?
