P2P usage after reaching monthly limit
cleddau
Hi all,
Can anyone tell me if I can still use p2p on the slower speed restriction after reaching my monthly limit? Can I use it at full speed during off peak times? At the moment I not able to connect with azureus at all.This only started after recieving an email telling me I'd reached my limit for the month. TIA
Mand
P2P is blocked once you reach the usage allowance, and all other traffic is reduced to 128k until your next billing date.
You can add extra usage at any point should you wish.
cleddau
So the non metered usage during off peak time is a lie then?
Plusnet Staff
Plusnet Staff
Fixes: 159
We don't count the off-peak usage towards your total, however if you reach your peak allowance then you are restricted at all times.
 Chris Parr
 Plusnet Staff
waipang
including off peak? so basically you pay to get your speed back up then..
