P2P Surf Option
P2P Surf Option
Currently the P2P Surf option has only 2 options available enable or disable
how about an option to schedule P2P Surf for being enabled/disabled
Have a grid setup with the days from mon-sun which each day being split into 24 - when clicking on a section you either enable/disable the option for that period of time
1 REPLY
P2P Surf Option
I would be sceptical about playing this tool myself (oo'er missus Smiley). The last time I had the p2p block on my account, it prevented access to the F9/ +Net newsgroup servers. It took ages for F9 to realise that this was the problem and a few accounts were reset to default. I haven't touched my seetings since, although if you are not using usenet it shouldn't be a problem.
Mark
