P2P Speeds
P2P Speeds
I am still experiencing very poor torrent speeds the only good period since the Ellacoya upgrade was the Christmas week which was very good. Currently downloading a torrent with 200 seeds and rising but only getting d/l speed between 1KB/s and 7KB/s on average.
Bt Speedtest was ok. I am on Broadband Premier is there any chance my profile is on Broadband Plus at your end?
James
P2P Speeds
Torrents and P2P are given a lower priority than other protocols on our network. We are currently having minor load balancing issues which may be part of the problem that you are experiencing.
I would suggest trying to reboot your connection and see if this makes any difference to the performance that you are seeing.
P2P Speeds
Much better now thanks following a reboot. Previously on ptn-ag1 now on ptn-ag2 even web browsing noticeably faster.
P2P Speeds
How do I do this?
Moderators note by John (johnessex) Full quote of preceding post removed as per the Link:rules
James
P2P Speeds
Try restarting your internet connection, either by removing the power cable to your modem, or by restarting your computer if you have a usb/pci modem.
You can visit http://usertools.plus.net/@gateway to find out which gateway you are connected to.
