P2P Problem Help!!
P2P Problem Help!!
Another problem ... they jus keep piling up
OK so none of my p2p's seem to be working
I have even configured ports especially for them ive tried programs like Limewire, Winmx and DC++ they all cannot download a thing
I need some suggestions why ....
and i have checked and my safe surf is off
arbitrabbit
P2P Problem Help!!
Not using the BT voyager 205 modem, are you?
P2P Problem Help!!
Isn't 'Voyager 205 a modem/router?
-Williams1662
arbitrabbit
P2P Problem Help!!
Yes, and there are issues with that when using p2p
suec45
P2P Problem Help!!
If all your p2p programs arent working but you can browse teh net/download, then it wont be a PN or BT problem,
it is most likely a port forwarding/firewall issue or something else to do with settings on your computer.
Even BB+ would give back SOME speed even if its only 10k
P2P Problem Help!!
Yeh im using BT voyager ... i take it its not the greatest router... hmm
worth gettin a new one and does any1 kno a cheap quality router ?
arbitrabbit
P2P Problem Help!!
Yes, there are issues... for details you can look at my other thread: http://portal.plus.net/central/forums/viewtopic.php?t=30137
As for a cheap replacement, there are many. Try a Dlink. Usually fairly cheap and reliable. SMC also works great.
P2P Problem Help!!
I had the same problem, used an old adsl modem i got free with tiscali when i was with them (Sagem F@st 800) and no problems with my p2p apps.
Couldnt figure out how to set up the port forwarding with the voyager so didnt bother, lol
