P2P Bit Torrent test torrent
I seem to remember a while ago someone posted a torrent link which is useful in determining if you've got issues either with your personal configuration or summit else.
The torrent file is one that has an abundance of seeds so that you know it should come down at the max speed your line will allow rather than relying upon thinking that it's a good torrent.
If someone knows this torrent file can you please post a link as I could find it when searching?
Cheers,
Alecto
They come and go, that's the problem, so the ones that were well seeded last year aren't.
But they were all versions of knoppix, so if you go to Knoppix and select the torrent option, that should do it.
cheers.
