P.A.Y.G. costs
m00nie
P.A.Y.G. costs
is it the same price per 2GB if you pre pay as if you dont?
thanks
Fixes: 8
P.A.Y.G. costs
The regular included allowance costs £1.50 for each 2GB chunk.
If you go over your included allowance it is charged at £1.80 for each additional 2GB (or part thereof).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
m00nie
P.A.Y.G. costs
thanks..
i need to up my allowance then to 6gb but the link dosent work for me, it gets stuck in a loop, any idea how i can do it?
Fixes: 8
P.A.Y.G. costs
Not heard of that problem before.
I suggest you raise a ticket saying what you want to set and describing what happens when you try to do it yourself.
m00nie
P.A.Y.G. costs
ok, thanks for your help
Cheesy
Plusnet Staff
Plusnet Staff
P.A.Y.G. costs
Where's the upgrade looping? Is it where you select the new amount? I've seen a couple of other reports of that and the developers are looking at it.
As jelv says, raise a ticket and the support team can change it for you.
m00nie
P.A.Y.G. costs
hi,
if i hit upgrade, then go to change my data transfer when i hit proceed it just takes me to the index page.
changing the the product just returns to the same options page.
(ive put in a ticket)
thanks
sam
P.A.Y.G. costs
Hi charlieboyall,
I have had a look on your account and the upgrade has been actioned, there is now an included 6GB on your account.
