Over reporting of useage on monday for my account
Anyone else think that they didn't DL as much as is being reported for Monday?
Or is that just me? :?
Fixes: 5
Remember uploads are included in the VMBU, and also if you are using P2P apps then you might get connection attempts for hours after you finish with it, even if your computer is off.
Should say as well, my usage looks about right for monday.
Phil
See my thread - http://portal.plus.net/central/forums/viewtopic.php?t=38176. It appears to be since the new VMBU came in.
Add to which, my changeover to my new ISP happened early this morning (before 02:00) but the VMBU still notched up 170M. Even the complete 12 - 8 period was notching up 170M so it looks like this is the minimum value regardless.
