Outlook email problem
Well Iv'e had that since last night
and it messes up my email.....................
Hi
I'm receiving the following error message when trying to receive email in outlook (pop3).
Task 'mail.plus.net - Receiving' reported error (0x800CCC0F) : 'The connection to the server was interrupted. If this problem continues, contact your server administrator or Internet service provider (ISP). The server responded: +OK 301 octets follow.'
I can still receive my email with no problem using web mail pop3 and imap.
Plusnet Staff
Plusnet Staff
Try logging in via to your email via webmail. You'll likely see a mail or two that are about 300 bytes in size and consist only of headers. There was a problem with one of the anti-virus servers that caused these "ghost" messages.
Just delete them via webmail and you shouldn't see them again.
sorted thanks
Well I keep checkin my web mail box and nothing like that there but still keep gettin the stupid message.
lhorwath
Hi Musicman,
I replied to your problem in the other thread.
regards
Luke
