Outlook and multiple addresses
shermans
I always have difficulty sending emails with several "cc"s. For some reason, they remain in the Outbox and do not get sent. If I use Plusnet Webmail to send them, there is never a problem. I suspect therefore that there is some sort of ant-spam setting either within Outlook itself, or within the Plusnet smtp server.
Can anyone suggest a cure ?
James
Tried disabling your AV software briefly to see if it has anything to do with it?
shermans
Thanks for the reply. I have now tried disconnecting both firewal and anti-virus software, but it makes no difference. Sometimes the email sits in the Outbox, othertimes it appears to go, but then I get an undeliverable message "No transport available to send this message".
If I send it out to only two of the adressees instead of five, there is no problem and it sends quite normally !
This Microsoft article might be of help here.
http://support.microsoft.com/kb/q197417/
and this one http://support.microsoft.com/kb/q176731/
Might be worth a read.
shermans
Thanks all ! All working again.
I do not like to admit it - in fact I hate to admit and so I am going to deny it - but there was a mistake in one of the email addresses which stopped all the others going as well.
I was looking for a logical reason and the only common denominator between ones I had previously sent in the past, where I had experienced similar problems, and this latest one was one particular addressee. I decided to check the details and found that the address was corrupted ! Outlook would not attempt to send it but Plusnet webmail always did !
So you see, it WAS Plusnet's fault after all ! Of course it was not MOI?
Glad you're sorted Smiley
