OrderTracker
OrderTracker
Hey I was wondering if anyone knew what could cause the "order tracker" function within "connection settings" to load a blank page.
Thanks.
OrderTracker
I think IE7 has some issues
are you using IE 7?
OrderTracker
At one point last week it was returning an error, but that seems to have been sorted now so I assume the errors been fixed.
If your using IE7 then you will have problems with the portal as there is a bug in IE7's CSS rendering
OrderTracker
I am currently having the issue with both firefox and IE6
