Option 3 Wireless Router
ggallagher
Hi ive just signed up to the new Option 3 BYW from Broadband Premier Option 1 mainly for the wireless router and because it saves me an extra couple of pound each month. Cheesy Can you tell me how long it usually takes to receive the new router etc and if you think i have made the right decision in switching? :?
Many Thanks
GavinG
Mand
You will need to raise a ticket to get the router sent out to you. This should then take a couple of days to actually reach you.
We are working on building this into the upgrade process for existing customers, but at the moment this is a manual process.
ggallagher
Could you tell me how to raise a ticket? Cheesy
Thanks again
Mand
By raising a ticket I mean using the Help Assistant to ask the support team a question.
You can raise your ticket by visiting this page.
Mand
Welcome to the forums btw. Smiley
