OpenOffice spellcheck problem
Fixes: 133
My apologies if this should not have been posted here but none of the other forums seem suitable. Maybe a mod could move it if deemed necessary.
I am attempting to get to grips with OpenOffice 2.2 but am finding the spellchecker always starts up with English USA.
Setting the language to UK in either the spellchecker's dialogue box or in Tools-Options seems to make no difference.
Any help, please?
Forum Moderator and Customer
Plusnet Staff
Plusnet Staff
Fixes: 159
Hmm I don't actually use open office myself.
1 idea though, when you installed the package was there an option for UK - English or was it just English?
 Chris Parr
 Plusnet Staff
omnia
Go to Tools-Options-OpenOffice.org-Language settings.
Choose Languages and make sure that User interface = default; Locale setting = English (UK); Default languages Western = English (UK).
Choose Writing Aids and for Available language modules, click Edit... Make sure that Language is set to English (UK).
Hope that this helps.
Fixes: 133
Thanks omniadesign.
I had been through those settings and they are already set as you describe.
Everytime the spellchecker is started it is in USA mode. I set it in the Dialogue box to UK but it resets to USA after each word is checked.
Edit: I have noticd that the same appears to hapen with the Thesaurus!
omnia
OpenOffice have a very good forum and if you post your query there, you should get an answer to your problem.
The url is: http://www.oooforum.org/
omnia
I have just checked the url I gave earlier and on the Openoffice.org Writer Forum, the first topic is a Tutorial for Spell check and Language configuration which addresses your problem.
http://www.oooforum.org/forum/viewtopic.phtml?t=50862
Fixes: 133
Thanks omniadesign, that was very interesting reading.
What I found was that all the settings were as described anyway. But, and here's the catch, anything I typed in a new document was automatiocally spellchecked in UK English but the previous document,downloaded from the local council, was still set to USA.
Further reading described the reasons for this and I think the workaround is too much hassel just for the odd document.
Thanks again for the pointer, much appreciated.
