One more question about SUP for the PlusNet CS. No ranting!
Are we going to be judged on actual usage or projected usage (as some have suggested). Its just that at the moment, I could be seen as heading towards the almighty limit ... this is mainly due to having a spangly new PC and new ISP and getting giddy with the usage. You can be guaranteed that this will go majorly downhill in a bit.
I just don't want to be restricted when it may appear that I could be at risk at the beginning of a period, but actual usage turns out to be nothing of the sort at the end.
JonathanW
Under the SUP people will be judged on their actual usage, and if this meets any of the levels set for profiling then the appropriate profile will be put in place. The projected usage figures are only for those people who are already on a profile and are trying to reduce their usage in order to have the profile removed early. Networks take their usage over a short period of time and from that project figures for a whole month.
Thankoo
