On Lite, being routed as homesurf?
Many thanks!
1 <10 ms <10 ms <10 ms 192.168.0.1
2 16 ms 31 ms 16 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
That does seem to have done the trick.
I'm not sure if this is a problem or not, but everytime I do a tracert I'm being routed as follows:
2 31 ms 16 ms 31 ms lo0-homesurf.ptn-ag2.plus.net [195.166.128.54]
I'm not on HomeSurf, I'm on the Lite account. My control panel has the restrictions turned off, too. I do note, however, that I cannot connect to the likes of free.teranews.com. Is this connected, as homesurf customers can't connect to external news servers?
Plusnet Staff
Plusnet Staff
I've seen this once before. Have you ever enabled the Surf option on the portal? And if so have you disconencted and reconencted since you turned it off?
I have had it on. I turned it off a few days ago. I've disconnected several times, but I'm resolutely routed through it.
Plusnet Staff
Plusnet Staff
OK, disconnect and reconenct and try it again. I've just reset your login settings so it should now work.
