Office 1000 - 2 websites ??
Robtheplod
Hi!
I hope to setup a new office 1000 adsl connection shortly, and hope to use both of the included domain name options. My question is that if this is done, can I also setup two websites for these domains ?? ie www.company1.co.uk www.company2.co.uk - these would both be completely seperate..
can this be done ??
cheers
rob
1 REPLY
fonejacker
RE: Office 1000 - 2 websites ??
Hi Rob,
Yep - it's easy!
In the "My domain names" > Configure > "Domain hosting settings" section (Once you register the domain) of the portal you will find a field for "Hosting Directory". By default this points to the /htdocs/ dirctory of your webspace, but you can create a directory inside /htdocs (ie /htdocs/site1/) and point the domain there instead.
Regards,
Ian Wild
PlusNet Customer Support
