OK where is the Sales phone number
mike001
Hi
I have a frend that is going to sign with +net IF I can find the dam sales number :-)
Anyone seen it
damned if I can find it Shockedops:
0845 1400 200 Smiley
mike001
Ok where was it :-)
It is in the Sales & Support section.
But I simply collected it from my memory, like so many other numbers lol. I dont know why I bother keeping numbers in my phone book lol.
Regards,
holdtight
Help & Support / Contact Us / By Phone
It used to be on the bottom of every page but plusnet deemed fit to
remove it causing even more confusion for its customers as if there
wasnt enough already :roll:
*edit*
must have hit submit the same time as you Tom, i got it from memory too
and ive only had to phone them twice in the three or so years ive been here
strange that as i often cant remember what happened yesterday Cheesy
Bill.
mike001
It used to be on the bottom of every page but plusnet deemed fit to remove it causing even more confusion for its customers as if there wasnt enough already :roll:
removing it is just daft...should be on the +nets home page
nowonder My frend or I could not find it ..thats just stupid
Thanks anyways
on that note i had to use googe to find the DNS servers and mail servers for plusnet, your search function is really quite bad
connection settings -> connection details
mike001
Um not on my connection settings -> connection details its not !
My reply was to Buz about mail and DNS info, not you.
To answer your Q, you can click on the sales enquiries link at the bottom of every page then go through the contact us section.
LiamM
You can't sign up over the phone, incidentally.. just in case thats what you wanted to do.
mike001
Actually that is what he wanted todo ......looks like he is going to use his mums adsl on AOL to signup with +net now :-)
1) why does that not show under your search button when you type in DNS servers or SMTP servers?
2) why can there not be a single page which DOES appear on the search (as hit #1) that has ALL your connection details, eg : dns servers, smtp servers, nntp servers etc etc etc
Ben_Brown
We are working to improve the search facility at the moment, however it will take some time to complete.
google manages to find it -- on your site :p
you could go for a "important details" page in the nav bar on the left? like under where it says tools?
