Non LLU status required...
Hi, currently I believe I'm on MAXDSL as my upload speed never goes about 448k [ADSL Guide speed tester] and I believe that determines non LLU!
If I'm right, for migration purposes I'd like it to stay that way - is there a PlusNet link that gives me future LLU opt out?
Thanks - TL
Ps. Thought I'd posted this earlier but be dammed if I can find it...
Yep looks like it.
PlusNet have suspended transfers for now, but I'd register at http://trials.plus.net (might have to log in first) and select the 'I would like to opt out of the LLU upgrade programme'.
This will ensure you're not migrated in the future if the transfers commence again.
Ah I see you've created a duplicate thread, easy to do when the portal is running slower than a ZX81 and it appears your message hasn't been posted when it has!
You might want to remove the other one, or I am sure the mods will delete or lock it otherwise.
<waves to mods> Cheesy </waves to mods>
Thanks - what is up with this site today - SO slow...
TL
